A system component attempting to process a received response from an I/O blade detected a conduit API failure.
This may be a result of low system resources, and may be resolved by reducing the number of features that are configured on the switch. Otherwise, report the problem to your switch support contact.
Debug-Summary
A conduit failure was detected posting return code %retcode% for slot %failSlot% while processing event response for slots %slotInfo%, pipe ID %pipeId% and conduit ID %conduitNum% .
| Name | Type |
| slotInfo | String |
| pipeId | String |
| conduitNum | uInt |
| retcode | String |
| failSlot | uInt |
